Thread: Section Head - Stagger Offsset Callout like Grid Head
    2010-04
    Gamehendge
    281
    Default Section Head - Stagger Offsset Callout like Grid Head
    Hello,
    Is there any way to Offset a Section Head in elevation like you can with a grid head? It appears that you can split the segment in plan so that the tags don't overlap, can this / or something similar be done in elevation / section? thanks.
    2005-06
    in the upper right corner
    3,508
    Default Re: Section Head - Stagger Offsset Callout like Grid Head
    Quote Originally Posted by Limbatus View Post
    Hello,
    Yes there is, not sure if I can explain it well because I don't have revit in front of me but..
    If you select the section marker and look at your options under modify, select split section tool and it gives you the tool to split the line, while in that same command, you can drag the portions away from each other and they stay connected with a perpendicular line. Once you've done that you can adjust all the lines in any direction you want.
    HTH
    2010-04
    Gamehendge
    281
    Thanks. for some reason, the section I was highlighting had SPLIT SECTION grayed out. I duplicated it copied over my 2D anos and was able to split the section. I appreciate your help - Limbatus
  1. Shared Parameters for Elevation Mark, Section Mark, Callout Head & View Reference Families.
    Last Post: 2021-04-21, 08:30 PM
  2. callout head for section....
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-02-02, 11:49 PM
  3. Callout Head
    By dsw98 in forum Revit Architecture - General
    Last Post: 2006-10-26, 02:59 PM
  4. Section Head & Callout tag LINE PROPERTIES
    By Alvin_Alejandro in forum Revit Architecture - General
    Last Post: 2005-09-10, 03:00 AM
  5. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 10:02 PM
