Results 1 to 1 of 1
Thread: CR214-1: Concrete BIM: The Use of Building Information Modeling for the Concrete Contractor
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CR214-1: Concrete BIM: The Use of Building Information Modeling for the Concrete Contractor
    Instructor: Dan Russell
    Class Description: This class will focus on using BIM as a tool for creation of a concrete construction (fabrication level) model and how to collaborate with designers and other subcontractors to avoid conflicts in the field once work has started. The class will start at the beginning and go through each step from start of design through the end of construction. Topics covered will include using Autodesk® Revit® Structure to create a model, collaborating with Autodesk® Navisworks®, breaking your model into individual concrete pours and creating lift drawings, extracting quantity information from Revit to Autodesk® Quantity Takeoff (QTO), linking your CPM Schedule to the model, and exporting your lift drawings to AutoCAD® for use by rebar and forming suppliers.
  1. 2013: Concrete Slab/Concrete Beam Join
    By lowm445034 in forum Revit Structure - General
    Last Post: 2013-11-21, 03:59 PM
  2. 2011 Concrete Building with FE concrete walls
    By ichandrinos106880 in forum Robot Structural Analysis
    Last Post: 2013-03-18, 11:51 AM
  3. 2012: Concrete Beam Won't Join Concrete Roof Slab at Ridge..HELP
    By tedg in forum Revit Structure - General
    Last Post: 2012-10-15, 07:15 PM
  4. Editing concrete parameters to show concrete type
    By Buzter in forum Revit Structure - General
    Last Post: 2010-02-08, 05:08 PM
