Instructor: Warren Medernach
Class Description: If you are interested in distributing geospatial data to the masses, then you don't want to miss this class. Learn how easy it can be to publish data directly to Autodesk MapGuide Enterprise from AutoCAD Map 3D. You will see how to connect to a variety of data sources through FDO Technology, stylize and theme your data to create a cartographic masterpiece, and finally, how to publish the data to MapGuide Enterprise. In addition, through the use of MapGuide Studio, you will also learn how quickly and easily a web application can be built around your published map data.
