Results 1 to 1 of 1
Thread: SE204-2: Concrete Reinforcement with Autodesk Revit Structure and Robot Structural Analysis
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE204-2: Concrete Reinforcement with Autodesk Revit Structure and Robot Structural Analysis
    Instructor: Brian Johnson
    Class Description: Learn how to model, analyze, and design concrete reinforcement using Autodesk Revit Structure and Autodesk Robot Structural Analysis Professional. This in-depth discussion will show you how to model rebar in Revit Structure using manual tools and extensions and how to analyze or design rebar using the reinforcing link to Robot. Explore the many rebar analyze and design tools in Robot for entire structure or for specific elements. Improve your production and reduce errors using Revit/Robot interoperability. Finally, learn some approaches to scheduling rebar on construction documents.
  1. Replies: 0
    Last Post: 2015-08-07, 05:36 PM
  2. Replies: 0
    Last Post: 2014-12-01, 03:51 AM
  3. SE118-1: Preparing Autodesk Revit Structure Models for Analysis in Robot Structural Analysis
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:48 AM
  4. Revit Structure 2009 to Robot Structural Analysis Professional 2009
    By mark.carson.217995 in forum Revit Structure - General
    Last Post: 2009-05-14, 01:47 PM
  5. Replies: 0
    Last Post: 2009-02-22, 01:44 PM
