Thread: CV118-5: Telling the Floodplain Truth With AutoCAD Civil 3D
    2012-11
    3,030
    Default CV118-5: Telling the Floodplain Truth With AutoCAD Civil 3D
    Instructor: James Wedding
    Class Description: This class will look at using AutoCAD Civil 3D to review, analyze, and manage floodplain information. On the front end, we'll use GIS data to understand existing ground and flood conditions.Then we'll use the HEC-RAS Extension to export data for analysis and return the information back to AutoCAD Civil 3D for creating floodplains, water surface profiles, and other exhibits intended for use in floodplain management.
    2017-04
    MONTANA
    5
    Default Re: CV118-5: Telling the Floodplain Truth With AutoCAD Civil 3D
    SEEMS LIKE A GOOD ARTICLE. NOT MUCH OUT THERE THAT I'VE FOUND YET ON FLOODPLAIN ANALYSIS WITH CIVIL 3D.
  1. CV118-6L: Making the Grade! Grading Techniques Using AutoCAD Civil 3D (Repeat)
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 05:09 AM
  2. CV118-4: Modeling Rivers, Channels, and Streams With AutoCAD Civil 3D 2010
    Last Post: 2014-12-01, 04:58 AM
  3. Replies: 0
    Last Post: 2014-12-01, 04:52 AM
  4. Dimensions not telling the truth
    By Mike Sealander in forum Revit Architecture - General
    Last Post: 2012-07-14, 11:15 AM
