Hi all,
I having a wierd issue i can't wrap my head around.
I am atempting to make a collector combine all connected flows and add them to the main connector.
I have already done this for mechanical equipment families, but when attempting this with plumbing fixtures it doensn't work, this is the situation:
My plumbing fixtures have a parameter where i add the flow, this is connected to the connector. this connector is set to preset.
I then draw a pipe form the fixture to the sub connections of the collector, these also have a parameter connected to them and are set to calculated.
Then for the main connection i have a parameter which combines all the other parameters of the sub connections. this one is set to preset again.
Example
flow sub-connection 1: 0.1L/s
flow sub-connection 2: 0.2L/s
flow sub-connection 3: 0.1L/s
flow main connection= flow sub-connection 1 + flow sub-connection 2 + flow sub-connection 3 = 0.4L/s
Now this parameter work fine, but when i connect this parameter to the connector and load it in project. It doesn't add the flows up anymore.
When i disconnect the parameter, they add up again.
No mather what i try every time i connect the paramter to the connector it refuses to calculate.
Anyone know what this could be, ive added some pictures that might make this a bit clearer.
Thanks in advance.
