Thread: Linework looks "fuzzy" in Acad 2015
    100 Club jgrande26's Avatar
    2001-10
    Down the rabbit hole
    196
    Question Linework looks "fuzzy" in Acad 2015
    I'm not sure if this is a hardware or software issue. I just started using AutoCAD 2015 which is very different from 2014. At the same time, I also got a new computer containing a low-end, unsupported graphics card. I requested a graphics and RAM upgrade but haven't received it yet. I turned off hardware acceleration and made sure display lineweights was turned off. Yet, my linework is still displayed as if weights are turned on. I'm not sure if this is just the way the new version is supposed to look and I have to get used to it, if there's a setting I'm not aware of that will fix it, or if my expected hardware upgrade will fix it.
    Earth
    9,805
    Default Re: Linework looks "fuzzy" in Acad 2015
    Have you tried setting LINESMOOTHING to "off"?
    R.K. McSwain | CAD Panacea |
    2001-10
    196
    That appeared to help. Thank you.
  1. AutoCAD LT 2015 Fehler beim Wechseln in die "Papieransicht"
    By mscharf695215 in forum AutoCAD LT - General
    Last Post: 2015-03-20, 07:59 AM
  2. Hiding a "Split Face" line other than using the linework tool
    By Joshua Kohl in forum Revit Architecture - General
    Last Post: 2010-05-04, 08:56 PM
  3. plotting not showing "show hidden" linework
    By t1.shep in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-11, 11:15 PM
  4. Replies: 1
    Last Post: 2007-01-25, 02:52 AM
  5. Wish list: "fuzzy" mates
    By diane.peters in forum Inventor Wish List
    Last Post: 2005-11-19, 08:03 PM
