Greetings all! and Happy New Year!
An issue we are having lately involves big multi-discipline projects that have both Civil 3D and Revit drawings and trying to use the SSM. if it is a solely civil project we are golden, we use the SSM; if it is solely a Revit project we are golden because we use the project list that comes with Revit. BUT the projects that involve both are a difficulty because, as far as I know, you cannot reference to any Revit drawings through the AutoCAD SSM. So we have tried to come up with some workarounds. 1.) we make a subset in the SSM that has the discipline and in parentheses after the discipline we put REVIT. 2.) and this one is more time consuming we will plot the Revit drawing to PDF and then create a placeholder drawing in AutoCAD to xref the PDF into and then add that drawing to the SSM. You have a sheet for the Revit drawing and can plublish from the SSM, but the one problem is that if revisions are done to the Revit drawing you need to remember to plot a PDF again to the same file that is xreffed into the AutoCAD placeholder drawing. Is anyone else doing something like this? are you doing something more efficient? Surely we are not the only outfit that is using both Civil 3D and Revit for their projects. Would be really interested to know someone elses take on this situation.
Thanks for reading.
