Results 1 to 8 of 8
Thread: Raster Image Plotting Problem
    2015-08
    4
    Default Raster Image Plotting Problem
    Image displays just fine in Model space, Paper space and Plot Preview. This issue is when it plots. Any and all devices plot with the same issue. The plot comes out with very pixelated stips of image and strips of missing image. Only the image is missing, all other objects plot just fine. See images.
    Plot Preview
    Plot Output
    2001-12
    St. Louis
    5,408
    Default Re: Raster Image Plotting Problem
    Out of curiosity, what format is the raster image? If you resave to another format and attach that, do you get the same result?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2015-08
    4
    Wanderer,
    I created a new drawing and inserted the tiff file per opposing corner coordinates and plotted from a viewport with the same view scale as... the original drawing with a .sid file reference (same .tiff file). The plot from the .sid drawing is the problem. The plot from the .tiff drawing is good. Weird?
    2015-08
    4
    Thanks for the response. I think you found the root of the issue. We use a .sid file for our aerial ortho drawings. It is the drawing with the .sid files producing the problem. When I made a new drawing and inserted the actual .tiff file to the same coordinates and scale and plotted the same area and scale... the .tiff drawing plot was just fine. I also checked this for archived aerial drawings and the issue is the same.
    What I am wondering now is why all of a sudden the change. The .sid files have always plotted just fine. What has happened in C3D suddenly to produce this problem? What setting needs fixed?
    2015-08
    4
    I found that it also makes a difference which way I reference the raster image. MAPIINSERT method produces the issue. Connecting with FDO solves the issue. So I guess it isn't the MrSID files but how they are referenced/connected.
    TN/KY Area
    1,640
    2
    Using the Mapiinsert uses a lot of memory where FDO doesn't require as much. If you have the RAM and extra disc space use the Mapioptions command and try to adjust the memory that gets used for images. Read the help file for some tips on it. Understanding swap files helps too.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by Jmurphy View Post
    While I haven't had the plotting problem the Mapinserted SID files have always made working in drawings slow. Got to remember to use FDO from now on.
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by CAPT-MOOSE View Post
    Interesting... you just never know what it will shake out to be. ~smh~
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Problem with rendering - Low Quality of the raster image
    By liamm in forum Revit - Rendering
    Last Post: 2011-09-26, 09:36 PM
  2. Problem plotting DWG with pdf/image xrefs
    By spy.zefiris in forum AutoCAD Plotting
    Last Post: 2011-02-09, 07:12 AM
  3. Insert Raster Image problem
    By doug.79572 in forum ACA General
    Last Post: 2009-03-27, 09:58 PM
  4. Raster Design 2008 Image Insert Transform Problem
    By Spokes in forum Raster Design - General
    Last Post: 2007-11-30, 04:58 PM
  5. Help with Raster Image!!!
    By kim.74445 in forum Revit Architecture - General
    Last Post: 2004-11-03, 12:43 AM
Tags for this Thread
