Thread: WblockClon​eObjects memory not disposed
    2015-01
    Default WblockClon​eObjects memory not disposed
    Hi,
    i need to read an external dwg and import only some entities.
    I use WblockCloneObjects, it work fine but i found a memory problem, the memory is not disposed
    and autocad memory process significantly increases after WblockCloneObjects.
    I tried both autocad 2013 and 2014, but same result, autocad memory increase and not disposed.
    Where is the problem?
    Thank you very much.
    [CommandMethod("TestClone", CommandFlags.Transparent)]
            public void TestClone()
                // repeated 20 times to highlight the memory consumption
                for (int i = 0; i < 20; i++)
                    ObjectIdCollection filteredIds = new ObjectIdCollection();
                    Database targetDb = ACAP.Application.DocumentManager.MdiActiveDocument​.Database;
                    using (Transaction trMain = targetDb.TransactionManager.StartTransaction())
                        using (Database db = new Database(false, true))
                            // read the source dwg
                            db.ReadDwgFile(@"D:\he10t.dwg", FileOpenMode.OpenForReadAndAllShare, true, "");
                            // get all entities
                            using (Transaction trSource = db.TransactionManager.StartTransaction())
                                BlockTable pBT = (BlockTable)trSource.GetObject(db.BlockTableId, OpenMode.ForRead, false);
                                BlockTableRecord pBTR = (BlockTableRecord)trSource.GetObject(pBT[BlockTabl​eRecord.ModelSpace], OpenMode.ForRead, false);
                                foreach (ObjectId id in pBTR)
                                    // ...open entity and filter
                                    filteredIds.Add(id);
                            // clone the filtered entities in current document
                            using (ACAP.DocumentLock dl = ACAP.Application.DocumentManager.MdiActiveDocument​.LockDocument())
                                using (IdMapping mapping = new IdMapping())
                                    // now clone the objects into the destdb
                                    ObjectId destDbMsId = SymbolUtilityServices.GetBlockModelSpaceId(targetD​b);
                                    db.WblockCloneObjects(filteredIds, destDbMsId, mapping, DuplicateRecordCloning.Replace, false);
                        trMain.Commit();
                    filteredIds.Dispose();
    Turlock, CA
    6,420
    Default Re: WblockClon​eObjects memory not disposed
    How are you determining that memory is increasing? Are you getting any errors?
    C:> ED WORKING....
    LinkedIn
    2009-11
    5,719
    Your ObjectIdCollection filterIds is only in scope for the CommandMethod, so there's no need to call Dispose();
    As for the DBObjects accessed via GetObject(), by wrapping your Transaction in a using statement (as I understand it), it (the Transaction) is aware of the Objects accessed, and disposes of them for you once you Commit() the Transaction, and exit the using statement.
    With regard to the side Database, Owen's pretty well covered that with you already in your duplicate thread, no?
    Otherwise, you might experiment to see if there's any difference in using StartOpenCloseTransaction() in lieu of StartTransaction().
    Separately, this article from Kean might be of use:
    Cleaning up after yourself: how and when to dispose of AutoCAD objects in .NET
    Cheers
    Computer Specs:
  1. 2011: Memory Crash (running out of memory)
    By gfreddog in forum AutoCAD General
    Last Post: 2012-04-19, 08:16 PM
  2. Out of Memory
    By kmarquis in forum Revit Architecture - General
    Last Post: 2012-01-30, 04:33 AM
  3. Replies: 4
    Last Post: 2011-09-13, 12:17 PM
  4. Question about memory and peak memory
    By gbelous in forum Hardware
    Last Post: 2010-04-02, 01:48 PM
  5. Replies: 3
    Last Post: 2009-10-03, 04:21 PM
