Thread: Some hatches are comming in at the wrong scale... sort of.
    2011-09
    308
    Unhappy Some hatches are comming in at the wrong scale... sort of.
    OK, I'm using LISP to do all this so I hope this is the best forum to post in.
    First, thanks to the mighty Lee Mac who helped me a great deal with this initially.
    Anyway,
    I have hatches set up using LISP in acaddoc.lsp. Here's an example of one:
    ;Aggregate
    (defun AGGREGATE ( / TMP CAS NHS)
        (setvar "CMDECHO" 0)
        (setq TMP (getvar 'clayer))
        (setq CAS (getvar 'cannoscalevalue))
        (setq NHS (/ 0.4300 CAS))
        (command
            "_.-layer" "_m" "L-HTCH-THIN" "_c" "1" "L-HTCH-THIN" ""
            "_.-hatch" "_p" "AGGREGAT" NHS "0" "_a" "_a" "_y" "" ""
            "cmdecho" "1"
            "_.-hatch"
        (while (= 1 (logand 1 (getvar 'cmdactive))) (vl-cmdf "\\"))
        (setvar 'clayer tmp)
        (princ)
    I then call that hatch from the tool palette thusly:
    ^C^C(if AGGREGATE (AGGREGATE) (princ "Aggregate not loaded."))
    This was working fine untill some kind of server "issue" last week. IT is not being forthcomming but suffice it to say that that AGGREGAT pattern and a few others went missing.
    No problem, I restored them from my "personal backup"
    Now however, those five patterns that were deleted (and ONLY THOSE) are comming in at 1/12th their expected size!!!.
    Same LISP code, same PAT file, but 1/12th the size.
    So aggregate used to look right at 0.430 (times cannoscalevalue) now needs to be set to 4.800 (times cannoscalevalue). I'm stumped.
    Its almost as if the PAT file had been changed, but as far as I can tell, it's identical. I'm going wacko!!!
    Any guidance at all is greatly appreciated.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Some hatches are comming in at the wrong scale... sort of.
    Sounds like a UNITS issue. Maybe this FAQ can help.
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    It looks like to me that the Insunits system variable is somehow changing the insertion scale of the hatch pattern.
    Try setting the insunits value to 0 before adding the hatch pattern.
    Maybe 1 or 2 if 0 doesn't work.
    P=
    AutomateCAD
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by jpcadconsulting347236 View Post
    AutoCAD doesn't provide an easy way to examine a loaded pattern. My guess is that they are not the same. Go to http://www.turvill.com/t2/free_stuff/ and download GETPAT.LSP so you can examine the difference in those patterns and add update your "personal backup".
    2011-09
    308
    They're the same.
    It turned out to be the the the MEASUREMENT variable was set to 1.
    http://help.autodesk.com/view/ACDLT/...7-A52AC0C7C8FE
    Thanks Gang!!!
  1. 2012: Surface at wrong scale
    By jmauro930585 in forum AutoCAD Civil 3D - General
    Last Post: 2012-12-20, 05:21 PM
  2. 2012: Multiple Anno-Scale Hatches
    By randyspear in forum AutoCAD General
    Last Post: 2011-11-09, 06:47 PM
  3. model scale wrong
    By asiple in forum NavisWorks - General
    Last Post: 2008-11-12, 11:05 PM
  4. Independent X Y Scale for Hatches
    Last Post: 2008-05-28, 06:45 PM
  5. Material at the wrong scale
    By tim.glass in forum ACA General
    Last Post: 2007-11-15, 04:52 PM
Tags for this Thread
