Results 1 to 6 of 6
Thread: Adding part information to modeled part.
    262
    Default Adding part information to modeled part.
    Hello everyone,
    I know that in an assembly I can click the BOM icon and I am able to add part information to each element that makes up my assembly such as:
    part numbers, cost, remarks, and even custom properties.
    So what happens if I model let's say a metal bracket and I save it into my library of parts. I would like to populate that part with the similar information as I mentioned above so that if and when it is inserted into an assembly, I don't have to re-key the information manually. If this possible if so can you please tell me where to look within the software of even the help file? I have had no luck.
    Thank you.
    262
    Default Re: Adding part information to modeled part.
    no one knows ?
    2012-06
    28
    When you open your part, Right mouse click on the partname in the browser and choose iProperties. Or do you mean something else?
    262
    Thank you, that is what I learned and I also learned to add custom properties. I really appreciate the help.
    I also learned a bit about iparts, I have a question but I am afraid to post it.
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by crullier View Post
    lol, don't be afraid... We don't bite... usually.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    262
    Quote Originally Posted by Wanderer View Post
    Here it is:
    If I make an ipart with a custom parameter for length (custom factory I believe it the terminology) When I bring such part into the assembly, I would like to "activate and drag" some sort of handle to size it rather then having to go the browser and right click on the table. I m afraid what I am asking is not possible / not a feature of the software.
  1. 2014: 'Add part sizes' - dialogue box stopped showing its information.
    By paavo.hurskainen676543 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2015-02-12, 03:41 PM
  2. Adding to Part of a List
    By stusic in forum AutoLISP
    Last Post: 2013-11-19, 05:58 PM
  3. Replies: 0
    Last Post: 2013-05-06, 01:33 AM
  4. Adding Part Number to Lookup Table
    By cdsuggs in forum Revit MEP - General
    Last Post: 2010-06-29, 06:14 PM
  5. Suppress Part Tag Information
    By jason.combs in forum Revit Architecture - General
    Last Post: 2009-12-23, 04:15 PM
