Thread: Select all elements on a specific Level
    2012-07
    Manchester, UK
    132
    Default Select all elements on a specific Level
    Hello,
    I have a rogue Level I need to delete from the model but nobody can tell me who created it, why, nor if it still has elements that are still being used in the project.
    Is there a quick, safe, way to be able to select all elements that are still using that level? I do not mind moving them all individually, just as long as I am sure that no other elements are in the level before I delete it.
    Many thanks for the help.
    J
    2004-06
    77
    Default Re: Select all elements on a specific Level
    You can download the free Trial of Ideate Explorer to address this issue. This video shows how.https://www.youtube.com/watch?v=CJnN...sKPG3Obvnf8ZSB
    2012-07
    Manchester, UK
    132
    Thanks.
    Autodesk Techinical Support suggested the following, which worked BTW
    To find the elements associated with level +15.00m you could create a schedule or to visually display the elements associated with this level, you could move the level far away from the other levels, view the view associated with the level and see the elements which have moved with the level (since the other elements are far away they View Range should prevent them from displaying).
  1. 2014: select all lineworked lines as a specific category override
    By jagostinho in forum Revit Architecture - General
    Last Post: 2014-11-17, 03:01 PM
  2. Lock view to specific elements?
    By jstaylor in forum Revit Architecture - General
    Last Post: 2012-01-18, 09:49 PM
  3. Hiding Specific Elements.
    By andrews-n in forum Revit Architecture - General
    Last Post: 2009-12-15, 04:41 PM
  4. Cannot paste view-specific Elements
    By ehull33 in forum Revit Architecture - General
    Last Post: 2009-12-07, 09:18 PM
  5. View Specific Level tags
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2006-05-08, 02:17 PM
Tags for this Thread
