Ok, I have searched and searched for answers on this and bubkis...
I export a DWF from a workset enabled revit project
When I open the sheets in Design Review, all of the model elements on the sheets are blurred and useless. I can not select any of the elements on sheets, they are kind of like a background thats not even in focus.
All of my grid lines, levels, and text are perfectly clear and also selectable. It is only the model elements that are basically useless.
I need to be able to resolve this, as we are using Design Review to communicate with the engineers of other disciplines...
I have tried exporting from other projects to see if its a software problem, and every other project I have exported has worked perfectly normally, so there is something somewhere in this particular project that is causing it.
My suspicions lean towards the worksets somehow causing this, however when I detach the file from central and destroy the worksets in the file, it still does exactly the same thing.
Help!!
Image from a normal project
image from the blurry project
