This thread may be of interest.
Cheers
Yeah there is a few people that do paste as block, not sure why.
I'll look at the Wblock but when i looked at this option at the start instead of the dxf it didnt shrink the file. If i manually select the items within the drawing it does make the new block file smaller but the layouts and page setups have to be redone. i guess thats why i like the dxf option.
Does anyone know how to get the DXF option to work?
Even if i specify the dxfin file name/path it seems to have errors with the path as there is spaces in the folder names - even putting " quote marks" or similar around the path doesnt help i still get an error half way through the file path.
so i guess simply its along the lines of
dxfout 16
dxfin filename
audit
yes
purge all * no
purge all * no
purge all * no
zoom E
save as
There was more to it originally but since it wasnt working properly i stripped it back to minimal just to get the dxf audit and purge to work before worrying about saving details etc.
So this produces a dxf of the file but then when it gets to the dxfin it errors on the filename (nomatter if its a correct path or not) then skips to the purge and audit, zooms and then the save as dialog box comes up however it has only audit and purged the original dwg file. it doesnt open the dxf file to audit and purge.
Is this because the script fails over two drawings or is it simply the pathname? eg.pathname - F:\Queensland\Mackay-KMD-Shop 2428, Caneland Central -14174\Documents\fileclean\14174 A101 [Ø].dxf
Thanks.
Thanks i have run the Autocad hotfix and didnt seem to reduce the file much interestingly enough. ill look at the ones in the thread see if they work any better.
