So today I was asked if I could turn off the fire rating material in a fine view detail.
I can turn off the cut pattern via VG, but this also removes the Cut pattern from the Gyp board.
We have our fire rated walls set with a material for the core that mimics the old fire tape patterns we used to see.
It'd be really nice to be able to add a line component to it, but you can't put letters in lines in revit from my understanding so that's out of the question.
What I did find is that you can assign a parameter to a material. So I thought gee, maybe I could assign a parameter for the material and then turn off only that material via a filter. Funny thing is that you can select a material category in a filter.
It would appear what I'm looking to do isn't really possible.
Any thoughts on how to hide the material with in the core layer of a wall without hiding the rest of the layers?
Thanks in advance.
