Results 1 to 10 of 11
Thread: 2006LT on Windows7?
    2012-01
    Default 2006LT on Windows7?
    I just got a computer that has Windows 7 and I want to install AutoCAD LT 2006. The pop-up window says the program is not compatible with this version of windows, and the computer just sits there and spins. Do you know if I can use the two together? Do I have to buy AutoCAD again?
    2009-11
    5,714
    Default Re: 2006LT on Windows7?
    Quote Originally Posted by mintzengr548172 View Post
    Welcome to AUGI.
    Too bad you didn't get a new computer with Win8.1 (or did you, and you've just not installed it yet?)... Because Win8.1 comes with Client Hyper-V, which allows you to create and manage virtual machines natively, where you *could* install WinXP on a VM, and then subsequently install 2006 on that instead.
    Cheers
    Computer Specs:
    0,0,0 The Origin
    8,570
    Any recent computer is almost certainly 64-bit capabable and is likely to be running a 64-bit version of Win_7.
    Your acad LT is almost certainly 32-bit.
    It MAY be possible to make it install and it MAY work okay but running (32-bit) WinXP in any of the available "Virtual Machine" products is a better bet.
    Earth
    9,803
    Quote Originally Posted by BlackBox View Post
    .... Because Win8.1 comes with Client Hyper-V, which allows you to create and manage virtual machines natively, where you *could* install WinXP on a VM, and then subsequently install 2006 on that instead.
    Is that different than "XP Mode" running in a VM on Win 7?
    R.K. McSwain | CAD Panacea |
    2009-11
    5,714
    I've never actually done that, so am unsure... As for my comment, I meant to actually install a valid license of WinXP (from their old box? They still own it) onto VM's bootable .VHDx
    Perusing the link, it comes off more like a 'parallels' for Windows, just relegated to WinXP (instead of any Mac\Win OS you want).
    [Edit] - XP Mode seems to be a feature limited precursor to Client Hyper-V as well.
    Cheers
    Computer Specs:
    Cairo - no, not Illinois
    5,069
    Cheers
    well, not according to the Microsoft license agreement. The license goes with the old machine, and can't simply be installed on a different box. even if the old box is being scrapped or converted to Limux. Your thinking makes perfect sense to a user, but not to a vendor of OS software
    (if the old licenses was a shrinkwrap full retail package, then yes, it could probably be installed - but not a OEM version.
    Getting back to the OP -- Try installing the free-to-use-for-any-purpose Draftsight program. If you're using 2006 LT, then the current version of Draftsight is probably going to be a step forward.
    2009-11
    5,714
    This is a good point to clarify.
    Any machine that you order that comes with non-transferable OS (aka OEM) has the product key injected into ROM on the machine's motherboard, and has no sticker from which to identify the product key being used. All machines in this office (I cannot comment for others') that include a sticker with the Win7/8.1 product keys are transferable under the terms of our VLSC, even if purchased through Dell (which all but those we upgraded were).
    Also worthy of note, is that Win10 is a free upgrade to any non-Enterprise Win7/8.1 license, so as to increase the adoption, and avoid the issue with Win8 (8.1 has been a fantastic upgrade from Win7, BTW).
    Cheers
    Computer Specs:
    Earth
    9,803
    In what ways?
    I really dislike Win8.1, especially compared to Win7.
    2009-11
    5,714
    In what ways?
    That's a loaded question, as I manage our IT as well as work in CAD; perhaps you could clarify what you dislike, and I can attempt to offer workarounds?
    Client Hyper-V has been the single best improvement for my work, both managing our infrastructure (not just RDP), and for sandboxing Win10 TP, Autodesk Betas, etc., but admittedly, not everyone will have the need for that.
    Cheers
    Computer Specs:
    Earth
    9,803
    Angry Re: 2006LT on Windows7?
    I admittedly do not use it frequently, but first off I have no need for any "touch" capability, so all that functionality is a waste. Secondly, I just do not get the whole interface with the squares.
    What is the point in that? All I really need is the standard taskbar with my 5 or 6 most used program icons. Yes, I know I can "switch over" to the now "old" normal desktop look, but I swear I hit the wrong key about every 5 minutes and BAM, I'm looking at squares again... #frustrating
    I am truly open to new things, but if it's not clearly intuitive, then it's not working.
  1. Non visable items - Windows7 & Adobe Pro
    By tonori in forum AutoCAD Plotting
    Last Post: 2011-05-04, 03:15 PM
  2. Konfiguration bei jedem Start von Windows7
    By Ziegler in forum AutoCAD LT - General
    Last Post: 2010-11-09, 06:40 AM
  3. Windows7- 64bit AVI problem
    By stephen.scott in forum 3ds Max - General
    Last Post: 2010-07-07, 05:36 PM
  4. Migrating? 2006LT
    By mr.drift2008 in forum CAD Management - General
    Last Post: 2008-09-21, 08:53 AM
