Thread: Revit Tagging - Slab Reinforcement
    2013-01
    13
    Default Revit Tagging - Slab Reinforcement
    Hi Guys,
    I'm trying to tidy up my area reinforcement tags for our slab designs. We use A B C & D as our bar notations with A being the first bar laid and D the last. At the moment I have a tag with 4 separate types for either the A, B, C or D bars using a visibility switch/parameter. Which is OK but I would like to make the tag a little smarter. Is there a way to use a formula to trigger the relevant tag instead of the visibility parameter?
    I've attached a copy of the tag family
    Interested to see if you guys have any ideas.
    Warm Regards
    2013-01
    13
    Default Re: Revit Tagging - Slab Reinforcement
    Hi Guys Anything?
    2005-07
    Somewhere in the BIM world
    3,792
    Tag's are simply showing data from the element tagged so there's no way to use formula in a tag.
  1. 2013: No Slab Reveal, so will Reinforcement work in Component?
    By tntdraftsol in forum Revit Structure - General
    Last Post: 2014-06-06, 08:48 PM
  2. Path reinforcement in sloping slab
    By JH75 in forum Revit Structure - General
    Last Post: 2010-05-05, 11:03 PM
  3. Area Reinforcement in slab
    By crickman in forum Revit Structure - General
    Last Post: 2009-07-27, 03:19 PM
  4. Thickened Slab Edge Reinforcement
    By j.pilot in forum Revit Structure - General
    Last Post: 2008-11-28, 02:36 AM
  5. Thickened Slab Edge Reinforcement
    By j.pilot in forum Revit Structure - Wish List
    Last Post: 2008-11-25, 02:05 PM
