Results 1 to 6 of 6
Thread: Graphical Column Schedule Problem
    2015-09
    146
    Thumbs up Graphical Column Schedule Problem
    I have made a graphical column schedule and I when I go to view it I cannot see anything. Please see attachment, there is columns in the model but in the graphical column schedule properties it says that there is none in the model. Does anybody know how to fix this ?
    Cheers
    2007-01
    226
    Default Re: Graphical Column Schedule Problem
    just a guess I would check your grids, if grids do not extend thru top to bottom, columns will be dropped from graphic column schedule...
    I have noticed this issue as problem before with the extends of grids.
    2015-09
    146
    No ive just tried this and still it is saying that there is no columns in the model, is it a family problem ? just wondering if anybody as come across this before
    2013-07
    Cleveland, OH
    56
    Can you post the project?
    2008-11
    Australia
    754
    Are your columns under the structural discipline? If not they will not show as your setting here is filtered to structural columns only.
    Maybe they are modeled under "coordination" or "architecture"
    2002-09
    Madison, WI
    5,688
    Other option is the levels at which the columns are modeled are not within the levels of the schedule.
    Or there's a filter on the schedule.
    Workset wasn't loaded in someone's local model then model was saved. I've run into that before. Pick on the light bulb in the GCS and see if anything shows up. Then turn it off. That seemed to do the trick in the past to re-set what ever gremlin was causing the issue.
  1. Graphical Column Schedule problem
    By j.pilot in forum Revit Structure - General
    Last Post: 2009-12-08, 01:54 PM
  2. Graphical column schedule - issue with column location mark
    By brent.vanlelyveld in forum Revit Structure - General
    Last Post: 2009-05-21, 07:58 PM
  3. Graphical column schedule problem
    Last Post: 2008-11-18, 09:38 PM
  4. Graphical Column Schedule and slab/column intersection not show correct in GCS
    By jonas.152865 in forum Revit Structure - General
    Last Post: 2008-07-16, 06:58 AM
  5. Graphical Column Schedule Problem
    Last Post: 2008-01-26, 12:06 AM
