once you have all objects to move, you must move each one by itself using the "Move" method (that applies to all drawing objects)
here's the AutoCAD ActiveX and VBA Reference example
Sub Example_Move()
' This example creates a circle and then performs
' a move on that circle.
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
' Define the points that make up the move vector
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 2: point2(1) = 0: point2(2) = 0
MsgBox "Move the circle 2 units in the X direction.", , "Move Example"
' Move the circle
circleObj.Move point1, point2
ZoomAll
MsgBox "Move completed.", , "Move Example"
End Sub
of course, you don't need all that circle/center/raidus stuff, but only points1 and point2 settings and then using a statament like
myObject.Move point1, point2
inside your iterating-through-your-objects loop
I'd also suggest you the following:
1) use selectionset to find your LightWeightPoly, instead of iterating through all your drawing objects
this will improve the overall performance of your routine
as an example you could use a function like the following
Sub SelectLWPolys(sset As AcadSelectionSet, myLayer As String, closed As Integer)
Dim gpCode(2) As Integer
Dim dataValue(2) As Variant
gpCode(0) = 0: dataValue(0) = "LWPOLYLINE"
gpCode(1) = 8: dataValue(1) = myLayer
gpCode(2) = 70: dataValue(2) = closed
ZoomExtents
sset.Select acSelectionSetAll, , , gpCode, dataValue
End Sub
to call in your main routine (passing 'oSSet', '0' and '1' as parameters) and have your selectionset filled with all LWPolys that match the criteria and then loop through them to get the one with colour = acWhite (hope there you'll find only one of them!)
2) you could use the technique of setting a selectionset I showed you in the previous post (http://forums.augi.com/showthread.ph...41#post1287341
i.e. use a statement like
Set oSSet = CreateSelectionSet("MySEL", ThisDrawing)
to get advantage of "CreateSelectionSet(SSset As String, Optional myDoc As Variant)" function to obtain a valid and empty brand new selection set
