Originally Posted by
BlackBox
We work a lot of hours as a small firm, and are trying to lessen the load on users (myself included), by enhancing our ability to work remotely when needed.
Our current environment, after the upgrades I implemented last year (since we hadn't upgraded in +/- 10 years), consists of a new Dell R620 primary physical server running Windows Server 2012 R2, that hosts our Exchange, File/DC, and Terminal Servers via Hyper-V. I also have two legacy physical servers that have been upgraded by adding (in each) Windows Server 2012 R2, a second processor, 4 x 2TB HDD physical disks as RAID virtual disk, and a 2 port Gigabit NIC PCIe card (so each has 4 ports).
These legacy servers are currently slated to become secondary, and tertiary replica nodes for CYA, but now that we're considering upgrades to support a substantially greater remote access load, I've held off with that until we identify any changes needed for this task.
At the moment, a few of us remote into our Terminal Server via RDP, and then RDP into our physical workstations to do our actual work.
There's obviously several factors at play here, but we're experiencing a bit of lag when it comes to cursor movements in Civil 3D, resulting in bad OSNAP selection, etc. (minor issues). We're on subscription for Infrastructure Design Suite, but really only use AutoCAD (Engineers), Civil 3D and Raster Design (Designers).
For those of you who work remotely for CAD design, and do not work locally using a 'project check out' procedure, what systems are you using to gain access to your remote server, and what hardware/software configuration are you using?
More specifically:
Are you remotely accessing your physical workstation in the office, or has your in-office workstation been virtualized (VDI) so regardless, you're actually working off of the server both in office, and remotely?
How many users simultaneously work remotely through a given Terminal Server, and what phsyical server resources have been dedicated to that Terminal Server's virtual machine via Hyper-V Settings, etc.?
Does your Terminal Server virtual machine's physical server host have a GPU card installed? If so, what card are you using to support Civil 3D design?
What sort of bandwidth should we anticipate needing, both in terms of the physical connection to the office, as well as the throughput via security appliance, before gaining access to our Gigabit network via Terminal Server?
Cheers
