Results 1 to 6 of 6
Thread: fail to get commcntrcontroller! error
    2004-07
    Lenexa, Kansas
    98
    Exclamation fail to get commcntrcontroller! error
    Hello, I get this error when starting acad lt 2005, this error started occurring in acad lt. 2004.
    I don't use acad at home much but this is starting to get annoying.
    -Start up stalls at 47% complete.
    -The task manager says autocad lt is "running".
    -In the processes menu "WSCommCntr1.exe" is using 50% of the CPU and is using 3.5M of memory.
    This happens for about 5-7 min. and then a error message shows up that says "fail to get commcntrcontroller!" I hit ok and the program runs fine.
    I asked about this on the autodesk web site but the had no good answers
    Thanks for your help... Jim
    2001-03
    13,499
    Default Re: fail to get commcntrcontroller! error
    Hi
    Have a browse of the following thread (please take note of any links within) -
    Communication Center causes hang ups in 2004 and 2005
    Have a good one, Mike
    2004-07
    Lenexa, Kansas
    98
    Thank you... Who needs communication center anyway?
    Administrator richard.binning's Avatar
    2001-05
    In the foothills of the appalachians
    2,258
    An old thread but sometimes helpful. I was trouble shooting an install of AutoCAD on an XP64 install today and resolved this problem by copying the WSComm... app from the Autodesk shared folder under (X86) program files to c:\program files\common files\Autodesk Shared (which did not exist).
    ...there's a reason certain apps are not certified for use on certain operating systems!
    0,0,0 The Origin
    8,029
    Quote Originally Posted by richard.binning View Post
    Interesting ...
    Thanks for the info.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2010-09
    Background:
    I am running 3ds Max 2009 32-bit on in Windows 7 64bit.
    When jobs are submitted to be rendered using Autodesk Backburner 2008.1, I see the following in the event log as follows and the rendered frames fail:
    <pre>
    Log Name: Application
    Source: Application Error
    Date: 9/27/2010 2:00:39 PM
    Event ID: 1000
    Task Category: (100)
    Level: Error
    Keywords: Classic
    User: N/A
    Computer:
    Description:
    Faulting application name: WSCommCntr1.exe, version: 17.2.56.0, time stamp: 0x47ae8d9e
    Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
    Exception code: 0xc0000005
    Fault offset: 0x00000000
    Faulting process id: 0x126c
    Faulting application start time: 0x01cb5e7dd0dd58db
    Faulting application path: C:\Program Files (x86)\Common Files\Autodesk Shared\WSCommCntr1.exe
    Faulting module path: unknown
    Report Id: e611a229-ca71-11df-91b5-20cf30934d50
    </pre>
    I started the service "interactive services detection" and saw errors in the application log as follows:
    <pre>
    Source: Interactive Services detection
    Date: 9/27/2010 1:54:27 PM
    Event ID: 1000
    Task Category: None
    Level: Information
    Keywords: Classic
    User: N/A
    Computer:
    Description:
    A device or program has requested attention. Device or application: C:\Program Files (x86)\Autodesk\3ds Max 2009\3dsmax.exe. Message title: Untitled - Project Folder: C:\Windows\system32\config\systemprofile\Documents\3dsmax - Autodesk 3ds Max 2009 - Unregistered Version - Display : OpenGL.
    </pre>
    Looking around more, I found this post describing the Autodesk Communication Center
    http://www.cadforum.cz/cadforum_en/r...r1-exe-tip6914
    While I wasn't running AutoCAD, the "communication center" appears to be the same executable program that 3ds Max uses for its "Information Center"
    Then I searched the registry for all instances of the word "Communication", which generated hundreds of results I manually sifted through. I then figured out that I needed to search more specifically for "CommunicationCenter" in the keys, values and data fields.
    I found the following registry key
    <pre>
    HKEY_CURRENT_USER\Software\Autodesk\3dsMax\11.0\MAX-1:409\WebServices\CommunicationCenter
    </pre>
    For the following value "EnableBubbleNotification", I changed the data from "1" to "0". This will disable the 3dsMax Information Center from appearing when 3dsMax is loaded as a standalone application or .
    I had to make sure to change it for all users throughout the registry, not just the current logged in user. This way running Autodesk Backburner 2008.1 as a service under different credentials would render successfully, without the prompting for user to switch to the program to close the "3dsMax information center"
    After that, the error stopped appearing. This solution disabled the information center and allowed Autodesk Backburner 2008.1 to continue to run in the background w/o user intervention.
    I hope this helps some one!
    Michael Zwarg
    IT Manager
    Knott Laboratory, LLC
    Last edited by mzwarg.263822; 2010-09-27 at 09:45 PM. Reason: took out sensitive info
  1. Fehlermeldung Autosketch CommCntrController
    By torben.bernhardt in forum Deutsch - AutoCAD LT / AutoSketch
    Last Post: 2008-12-08, 11:54 AM
  2. seek fail error
    By FOUTJM in forum Revit Structure - General
    Last Post: 2007-02-01, 04:59 PM
  3. Replies: 3
    Last Post: 2006-12-26, 02:59 AM
  4. Replies: 1
    Last Post: 2006-02-03, 09:35 PM
  5. Fail to get commcntrcontroller!
    By jenniferchavez in forum Land Desktop - General
    Last Post: 2005-01-25, 03:04 PM
