Thread: How to extend a stair steel support under the landing?
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Question How to extend a stair steel support under the landing?
    I have a staircase (Assembled Stair) with steel supports. I can't get the steel supports to switch to a horizontal orientation under the end landing. I've tried both with an elongated final tread and with a landing. I expecting to be able to click on the edge of the landing to give it a support, but no such option came up as far as I could tell.
    I've tried to search for an answer but get lots of more general hits on stair problems.
    Anyone able to offer a suggestion?
    Here is a picture of what I want, drawn over here in 2d:
    2006-09
    Denmark
    621
    Default Re: How to extend a stair steel support under the landing?
    If someone has a pretty good idea that this can't be done, that would also be good information. I'm starting to wonder if an assembly would be better - it just seems stupid when we have the stair tool right there.
    2010-10
    Chicago, IL
    376
    I’m not sure what kind of steel support you’re looking for, your picture doesn’t show much, but take a look in here – it could help.
  1. 2013 - Stair Run / Stair Landing Joins
    By saeborne in forum Revit Architecture - General
    Last Post: 2012-10-04, 03:05 PM
  2. 2012: Single run steel stairs with landing?
    Last Post: 2012-01-27, 03:17 PM
  3. Landing lower than stair
    By wladaz in forum Revit Structure - General
    Last Post: 2008-12-01, 02:34 PM
  4. Landing at top of steel stairs?
    Last Post: 2007-07-13, 07:54 PM
  5. Stepped stair landing
    By kevin.matherly in forum Revit Architecture - General
    Last Post: 2006-08-20, 01:55 AM
Tags for this Thread
