Results 1 to 6 of 6
Thread: Adding information to the project
    2001-07
    488
    Default Adding information to the project
    I need to add the client's phone number to the project information parameters. How do I do that? thanks
    2003-05
    5,153
    Default Re: Adding information to the project
    Create a new shared parameter ( ph # ) as a text type.
    Open your titleblock family and place a label, then assign the new shared parameter ( ph # ) to that label.
    Close and save the titleblock family.
    Open a project.
    Select Settings, Project Parameters and add the shared parameter to the project, assigning it the category " Project Information"
    Load the new titlesheet ( with the new label ) into the project.
    Open Settings, Project Information and you will now have a field - ph #, where you can add this .
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    If you don't want to hassle making a new titleblock, simply type the phone number on one sheet while in Drafting View. Then, copy the number to the clipboard and go to all the other sheets using Edit>Paste Aligned>Current View.
    Sometimes I get carried away with parameters and trying to make "something for everything". Individual solutions per project are still O.K.
    Just an idea
    Steve
    I do use Beegee's approach for sheet instance parameters which I use on every project, like "Preliminary Drawing - Not for Construction" and my seal etc.
    2002-02
    St. Louis, MO
    4,695
    Actually a drafting view can only be place on one sheet.
    However a legen view can be placed on many sheets. So use a legend view.
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    Sorry for the confusion. I did not mean a drafting view. What I was trying to say was to simply add a text note to the titlesheet while in drafting mode. Then copy and paste align to all of the other sheets one by one.
    Text notes can be copied sheet to sheet.
    Sorry again
    Steve
    2002-02
    St. Louis, MO
    4,695
    I would add that if the information is to be the same on each sheet. Either use a legend view or group the information before pasting it from place to place. This way you can update all sheets in one action.
  1. Scheduling Project Information with Shared Parameters in Multi-Building Project
    By ddragoo144336 in forum Revit Architecture - General
    Last Post: 2010-08-20, 05:36 PM
  2. Adding Parameters to Project Information Revit 2010
    By leothebuilder in forum Revit Architecture - General
    Last Post: 2009-06-16, 12:54 AM
  3. Replies: 2
    Last Post: 2007-10-30, 08:24 PM
  4. Replies: 2
  5. project information (adding in shared parameters)
    By jarod.tulanowski in forum Revit Architecture - General
    Last Post: 2004-12-21, 09:46 PM
