neightyeight
It appears that you have tried to dimension the geometry, not the underlying linework that controls the geometry. You want to edit the extrusion, apply a radial dimension to the circle that is the basis of the cylindrical extrusion, map that dimension to your parameter and then click the green check box to finish the extrusion. Now the radius of your cylinder can be controlled via the parameter. I usually check the box to show centermark of the circle and lock this to the reference planes so it won't slide in the XY plane. The height of the extrusion can be controlled in various ways, but the standard one is to use reference planes. First, you would dimension and constrain the reference planes. Then lock the extrusion grips to those reference planes.
