I had a discussion last year with a member here about error handling.
So I came up with example that demonstrates what I was talking about.
I get tired of typing vla-get- and vla-put- or vlax-get and vlax-put on every activex command,
I get tired of wrapping an error trap around each ActiveX call.
I get tired of converting entity names, elists, handles, objectID's to objects before every Activex call.
Hence I present a useful alternative.
I am interested in your opinions.
;___________________________________________________________________________________________________________
; Function builder to create new function calls that include
; Written By: Peter Jamtgaard copyright 2015
; Errortrapping
; Returns T or Value for success
; Returns nil for failure
; Changes objects on locked layers
; Shorter Names
; vla-get-color becomes color
; vla-put-color becomes colorput
; Various methods of referencing an object including
; vla-Object
; Ename
; Entsel
; Elist
; Handle
; ObjectID
; Accepts Variant Safearrays and Lists as arguments (like for points)
; Return Lists in lieu of Variant Safearrays for points.
; Four properties already are lisp expressions Angle, Handle, Length and Type so those functions are
; AngleGet, HandleGet, LengthGet and TypeGet
; Ability to personalize functions to your developer prefix by changing the strPrefix string below.
; Function to demonstrate functionality
(defun C:TestShort (/ entSelection lstSelection objSelection strHandle)
(and
(setq lstSelection (entsel "\nSelect Object: "))
(setq entSelection (car lstSelection))
(setq objSelection (vlax-ename->vla-object entSelection))
(setq strHandle (handleGet lstSelection))
(layerput entSelection "0")
(linetypeput objSelection "Hidden"); If Hidden exists
; (colorput entSelection -1); <- Causes Error and stops routine
(princ "\nComplete")
; Function to build new functions calls
(defun FunctionBuild (strFunctionName / strPrefix strSuffix)
(setq strPrefix "")
(setq strSuffix "")
(or
(and (wcmatch (strcase strFunctionName) "VLA-GET-*")
(or
(and
(wcmatch (strcase (substr strFunctionName 9)) "ANGLE,LENGTH,TYPE,HANDLE")
(GetFunction strFunctionName strPrefix (strcat strSuffix "Get"))
(GetFunction strFunctionName strPrefix strSuffix)
(and (wcmatch (strcase strFunctionName) "VLA-PUT-*")
(PutFunction strFunctionName strPrefix strSuffix)
; Function to create new functions to read (get) com properties with built in error checking
(defun GetFunction (strFunctionName strPrefix strSuffix)
(and
(setq strFunctionName (substr strFunctionName 9))
(eval
(read
(strcat "(defun " (strcat strPrefix strFunctionName strSuffix)
" (obj)(errortrap '(vlax-get (toobject obj) \"" strFunctionName "\")))")
; Function to create new functions to manipulating (put) com properties with built in error checking
(defun PutFunction (strFunctionName strPrefix strSuffix)
(and
(eval
(read
"Put (obj Value)(propertyput (toobject obj) \"" strFunctionName "\" Value))")
; Standard Error Trap
(defun ErrorTrap (symFunction / objError result)
(if (vl-catch-all-error-p
(setq objError (vl-catch-all-apply
'(lambda (X)(set X (eval symFunction)))
(list 'result))))
nil
(if result result 'T)
; The toobject function converts objects, entitynames, entity selections, entitylists, handles or objectid's
; to object references. Returns nil if unsuccessful.
(defun ToObject (value / symType)
(setq symType (type value))
; Vla-Object
(if (= symType 'vla-object)
value
; Entity Name
(if (= symType 'ENAME)
(vlax-ename->vla-object value)
; Handle
(if (and (= symType 'STR)
(setq value (handent value))
(entget value))
(toobject value)
; EntSelection
(if (and (= symType 'LIST)
(= (type (car value)) 'ENAME))
(toobject (car value))
; Entity List
(= (type (car value)) 'LIST)
(= (type (cdar value)) 'ENAME)
(toobject (cdar value))
; Object ID
(if (and (= symType 'INT)
(= (strlen (itoa value)) 10))
(errortrap (quote (vla-objectidtoobject
(vla-get-activedocument
(vlax-get-acad-object))
value
(vl-load-com)
;See next post for rest of code or look at attachment
(apply 'or (mapcar 'FunctionBuild (atoms-family 1)))
