Scenario: 15 sheets issued for construction on 1/1/2015. Two weeks later, 10 sheets are revised and released in bulletin #1 (1/15/2015). Two weeks later, 5 of those sheets are revised again and released as bulletin #2 (1/29/2015).
Is there a way to hide/grey the revision clouds for bulletin 1 only on the 5 sheets that have been reissued as bulletin #2? Changing the "show" settings in the revision dialog will remove them from all sheets (including the 5 that were bulletin 1 but not bulletin 2) so that is not good. I tried making a subcategory to revisions in the object styles, but you cant apply a subcategory to revision clouds. The V/G dialog controls all revision clouds, not past ones.
The only way I see to accomplish this is to select all of them and manually "hide in view" or "override graphics in view" to halftone it. Is this the only way? This could become a long process if there are many sheets and many clouds per sheet (especially since you cant use the "select all in view" with clouds).
I am hoping there is a setting somewhere to override the graphics of old/previous revisions.
Thanks in advance.
