I'm interested in going down a row in excel copying values one by one then using the code I posted(with hopefully minor alterations) enter them into autocad. The code I posted takes values from a defined column and inserts it into new insertion points. My Goal is to automate property lookup entries by clicking a given number say 1 three times to get to 11 (1,10,11).
I have the number of clicks entered in a excel spreadsheet. In order to do this I need help with a few things.
1. First is simply typing the number(not as text command, but as sendkey(or equivalent))
2. Second is sending a up keystroke.
Option Explicit
Sub AddText()
'This macro adds text in AutoCAD using data - insertion point, text height and text message - from Excel.
'Moreover, it provides some optional parameters, so that the user can adjust the alignment, the rotation angle,
'the width factor and the color of the text to be inserted (using the Red, Green and Blue parameters).
'The code uses late binding, so no reference to external AutoCAD (type) library is required.
'It goes without saying that AutoCAD must be installed at your computer before running this code.
'Written By: Christos Samaras
'Date: 07/03/2014
'Last Update: 16/03/2015
'E-mail: xristos.samaras@gmail.com
'Site: http://www.myengineeringworld.net
'Declaring the necessary variables.
Dim acadApp As Object
Dim acadDoc As Object
Dim acadText As Object
Dim acadColor As Object
Dim LastRow As Long
Dim i As Long
Dim InsertionPoint(0 To 2) As Double
Dim ZeroPoint(0 To 2) As Double
'Activate the coordinates sheet and find the last row.
With Sheets("Coordinates")
.Activate
LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
End With
'Check if there are coordinates for at least one text message.
If LastRow < 2 Then
MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error"
Exit Sub
End If
'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If acadApp Is Nothing Then
Set acadApp = CreateObject("AutoCAD.Application")
acadApp.Visible = True
End If
'Check (again) if there is an AutoCAD object.
MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
Exit Sub
End If
On Error GoTo 0
'If there is no active drawing create a new one.
Set acadDoc = acadApp.ActiveDocument
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
End If
On Error GoTo 0
'Check if the active space is paper space and change it to model space.
If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding
End If
'Set the AcCmColor object (here acadColor) which represents colors.
Set acadColor = acadApp.GetInterfaceObject("AutoCAD.AcCmColor." & Left(acadApp.Version, 2))
'The point at the beginning of 3 axes.
ZeroPoint(0) = 0
ZeroPoint(1) = 0
ZeroPoint(2) = 0
'Loop through all the rows and add the corresponding text in AutoCAD.
For i = 2 To LastRow
'If the height and the message are not empty, add the text.
If IsEmpty(.Range("D" & i)) = False And IsEmpty(.Range("E" & i)) = False Then
'Set the insertion point.
InsertionPoint(0) = .Range("A" & i).Value
InsertionPoint(1) = .Range("B" & i).Value
InsertionPoint(2) = .Range("C" & i).Value
'Add the text.
Set acadText = acadDoc.ModelSpace.AddText(.Range("E" & i), InsertionPoint, .Range("D" & i))
'Align the text based on alignment selection. The default is left.
If IsEmpty(.Range("F" & i)) = False Then
If UCase(.Range("F" & i)) = "CENTER" Then
acadText.Alignment = 1
acadText.Move ZeroPoint, InsertionPoint
End If
If UCase(.Range("F" & i)) = "RIGHT" Then
acadText.Alignment = 2
End If
End If
'If the rotation angle is not empty, rotate the text.
'0.0174532925 is used to convert from degrees to radians.
If IsEmpty(.Range("G" & i)) = False Then acadText.Rotate InsertionPoint, .Range("G" & i).Value * 0.0174532925
'If the width factor is not empty, apply the width factor.
If IsEmpty(.Range("H" & i)) = False Then acadText.ScaleFactor = .Range("H" & i)
'Use the sheet data to change the color on each line of text (if the corresponding cells are not empty).
If IsEmpty(.Range("I" & i)) = False And IsEmpty(.Range("J" & i)) = False And IsEmpty(.Range("K" & i)) = False Then
Call acadColor.SetRGB(.Range("I" & i), .Range("J" & i), .Range("K" & i))
'Change the color of text.
acadText.TrueColor = acadColor
End If
End If
Next i
End With
'Zoom in to the drawing area.
acadApp.ZoomExtents
'Release the objects.
Set acadText = Nothing
Set acadDoc = Nothing
Set acadApp = Nothing
'Inform the user about the process.
MsgBox "The text was successfully added in AutoCAD!", vbInformation, "Finished"
End Sub
