I have a door family that has multiple types of doors within it, solid door, full glass, half glass, etc. I want to keep it a generic door in terms of door and frame material and finishes so that I don't have to create a new family for pressed steel frame, aluminum frame, etc.
My question is: Is it possible to take my door family and add a Yes/No parameter (or some other option) and create a list of possible door frame materials so when I insert my basic door, I can then select each door individually and select the door frame material in the Properties window. The important part of this is for my door schedule to be able to populate that particular door with whichever frame material I selected in the properties window.
Ideally I could use the same door family everywhere in the project, then go back and choose which doors have which frame type, then have the door family and door schedule communicate to reflect it. I want to avoid having to create a door family with multiple door types with pressed steel frame, and another family with aluminum frames, and so on...I'd just have to do it manually in the schedule at that point I assume.
Thanks
