Thread: Using curtain walls and sloped glazing for insulated wall panels
    2012-10
    18
    Default Using curtain walls and sloped glazing for insulated wall panels
    One of the projects I'm working on has a plant room which is builth up out of a steel frame with c-studs and then externally we are using a kingspan insulated panel. As it is now it's modeled as a wall and looks like a wall with some reveals in it to make up panel joins.
    I have been wanting to re-model this correctly with wall panels as it were constructed using the curtain wall and sloped glazing tools. Kingspan have a bunch of revit families for their panel which I've used to setup a curtain family that suits the panel sizes we are using.
    I'm stumped though on how to create the corner panel, both curtain walls won't join in the same way as a normal wall does. I've attached an image of what I'm trying to achieve and one that shows the join at the corners which I would like to have as a corner panel.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Re: Using curtain walls and sloped glazing for insulated wall panels
    This may not be the best way, but technically you could create a custom wall hosted panel for the edge. It would just be a wall based component that looked like the intersection you require, but it would work.
  1. Custom curtain wall panels on curved and slanted curtain walls/systems
    By AP23 in forum Revit Architecture - General
    Last Post: 2008-06-02, 09:08 PM
  2. offset glazing panels in a curtain wall.
    By brendan.mac in forum Revit Architecture - General
    Last Post: 2006-02-06, 10:53 PM
  3. Joining curtain walls & sloped glazing
    By studio3p in forum Revit Architecture - General
    Last Post: 2006-01-26, 01:45 AM
  4. 2 Questions - Curtain Wall Panels and Sloped Glazing
    By artitech in forum Revit Architecture - General
    Last Post: 2005-05-05, 12:15 AM
  5. 2 Questions - Curtain Wall Panels and Sloped Glazing
    By artitech in forum Revit Architecture - Families
    Last Post: 2005-05-04, 03:28 AM
