Thread: Block Authoring Palette (Dynamic blocks) Empty
    2005-09
    184
    Default Block Authoring Palette (Dynamic blocks) Empty
    Any idea why my Block Authoring Palette in the block editor would be completely blank ?
    Path is there
    Files are there
    ALL tabs are blank as seen in the snippit
    (sorry the image is so big, how can i correct that ?)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Block Authoring Palette (Dynamic blocks) Empty
    Tool Palette corruption. File access permissions. The moon rotating in a counter-clockwise motion. Other than that, I got nothing.
    2005-09
    184
    Yeah... Me neither.... consider that AutoCAD was being 'sensitive' like it sometimes can be.
    So, this is what I did.... I started looking into the file folders and quickly noticed very small file sizes. I went to another workstation and pulled those files from there and copied/overwrote the files on my computer.
    I re-opened CAD and they were thankfully there.
    Hope this helps someone in the future... thanks for the reply
    2002-01
    jUSt Here (a lot)
    9,106
    Looks like Tool Palette corruption wins. Thanks for posting your solution.
  1. Sharing Dynamic Blocks - Palette & Catalogue Issues
    By Warr_E_Er in forum Dynamic Blocks - Technical
    Last Post: 2014-08-13, 09:15 PM
  2. 2013: New install of 2013 Blank Dynamic Block Authoring Palette
    By paul145177 in forum Dynamic Blocks - Technical
    Last Post: 2012-10-02, 08:00 PM
  3. Dynamic Blocks.dwg contains authoring elements. Open in Block Editor?
    By johnd in forum Dynamic Blocks - Technical
    Last Post: 2011-07-07, 12:40 PM
  4. ObjectModified & Properties Palette & Dynamic Blocks
    By jamie.159739 in forum Dot Net API
    Last Post: 2008-02-07, 07:39 PM
  5. Dynamic Blocks.dwg contains authoring elements. Open in Block Editor
    Last Post: 2007-04-18, 08:36 PM
