Summary: Add the ability to insert a ceiling tag on an RCP that calls out the material and height of the underside of a floor assembly.
Description: We often use UL Floor assemblies to building many of our projects. Included in the UL assembly is a finish ceiling at the underside of a floor structure. This component is often associated with the fire resistance qualities of the floor, but in many cases doubles as our finished ceiling.
We do not want to have to create two separate assemblies (floor and ceiling) in order to create this UL type as it introduces the opportunity for user error if the assembly has to be created from two separate objects.
It would be great if you could tag the underside of a floor assembly in an RCP with a ceiling tag.
Product and Feature: Revit Architecture - Annotation Tools
Submitted By: Justin Pelland on 04/08/2015
