I have never been able to create a corner mullion that actually works in the model with out too much trouble. I have even created corner mullions that will work in one project but not in another even though the walls are created the same. Does anyone know a solid way that works time and again.
There has to be an easier way. At #1 and #2 you can see where I have just placed the mullion at all 4 corners knowing that I will need a different profile for IS corners over OS corners. I just wanted to be able to see how placing it in the profile mullion template would affect how it comes in.
#3 is the one that should work, but even when I get this close no amount of moving left right up or down will bring it to the right placement.
#4 & #5 shows you where I have finally given up and toggled the type properties along with the placement of the curtain wall completely. To get them in correctly I have to unjoin the two walls. This can't be right?
Any suggestions anyone anyone anyone Buhler...............
