I have a .dsd file (consist of 50-100 drawings) which I load every time I need to plot on PDF through publish command, I noticed that when I rename the Layout (by opening the drawing in another Autocad session, while Publish was still active in another session) and save, close it, then I will remove this specific drawing from my publish dialog box then add it again, expecting that the new layout name will appear, but it's not, the old layout name still there. My current solution is to close the publish dialog box and load the dsd file again and remove the opposing drawing and add it again, but loading the drawing takes time and I want to avoid it.
What I'm trying to say is, after I save the drawing, the "Publish" should read the new layout name, so I would not need to close and wait for my drawings to load again.
