Hello, I'm trying to load my code and actually I can't do it. It tells me a file was successfully loaded however I can't see anything. I'm not sure if my code doesn't have any errors. Can someone assist me?
Welcome to the AUGI forums!
Are you using the Visual LISP Integrated Development Environment (Visual LISP IDE) (Manage ribbon tab, Applications panel, Visual LISP Editor tool) to write and/or load the code? Or are you loading the code at the command line? (load "mylispfile")
Are you creating a command function, or just loading code that runs when loaded?
Can you share the code, or, if not, can you provide any command-line messages you get when you load the code?
