I have a fairly large dynamic block that is fairly sporadic.
When I attsync it, some fields within attributes lose there values, lookup strings, or object measurements. while others update...
Not as many lose there values with the sync button in battman command
This dynamic block contains up words of 500 parameters.
Also, approximately 20 plus lookup tables
No constraints are used...
Is this a common occurrence with complex dynamic blocks?
I'd prefer not to post the block since I've spent weeks to months working on it, but may if its absolutely nessecary
