Thread: Converting a SketchUp file to a schedulable Revit Family
    2008-12
    West Roxbury, MA
    124
    Default Converting a SketchUp file to a schedulable Revit Family
    Hi,
    It's 3 am, I'm on a deadline, and I found the faucet I want to spec. Trouble is, it's only in a SketchUp format:
    http://www.brizo.com/kitchen/vuelo/f...l#.VUMeGvlVhBc
    I downloaded the .SKP file, I brought it in to my Revit project as an in-place mass. I need to tag it and schedule it as a plumbing fixture. Trouble is, it won't let me change the category to anything other than a mass. Really?
    I've hit a roadblock against what seems to me ought to be really simple. Anyone have a quick, simple solution? This is not an easy object to re-model due to its complex shape.
    Derek
    2015-12
    Vancouver, BC Canada
    3,753
    2
    Default Re: Converting a SketchUp file to a schedulable Revit Family
    Families created in the mass category can't be changed to any other object category and families created as any other object category can't be changed to a mass.
    Import the skp file into a generic model template and the convert to a plumbing fixture and you'll be fine. You can also just bring it into a plumbing fixture template but it might have a bunch of default stuff you probably don't need.
    2008-12
    West Roxbury, MA
    124
    Quote Originally Posted by Dimitri Harvalias View Post
    Import the sip file into a generic model template and the convert to a plumbing fixture and you'll be fine. You can also just bring it into a plumbing fixture template but it might have a bunch of default stuff you probably don't need.
    Thanks Dimitri! For some reason I thought I couldn't import a SketchUp family directly into Revit 2014 without first converting it to a DWG. Is this a new thing for 2014? Anyway, it's scheduling now as a plumbing fixture and I'm going to finally go to bed. Thx for the help!
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    What timing!!!! Just this morning I looked up loading a skp file into Revit, after learning that KraftMaid kitchen cabinets have been posted as full 3D on Google 3D warehouse!
  1. Replies: 0
    Last Post: 2014-10-27, 03:48 PM
  2. 2013: Dim. vs. Layer when converting Revit file to ACAD file
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2013-10-02, 12:45 PM
  3. exporting revit file into sketchup
    By dac-sektion in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-03-29, 02:06 PM
  4. 2012: Schedulable family info
    By Duncan Lithgow in forum Revit Architecture - General
    Last Post: 2012-03-02, 06:37 AM
  5. Link a Sketchup file (via dwg) to Revit
    By dc.109967 in forum Revit Architecture - General
    Last Post: 2009-02-09, 03:36 PM
Tags for this Thread
