Thread: Match Dynamic Property Values IF Parameter Name =
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    158
    Default Match Dynamic Property Values IF Parameter Name =
    As with all coding...I'm so close but yet so far...
    So what I am after is any help getting the code below to run correctly. The user is prompted to select a dynamic block with or without attributes. The code would create a matrix of all the dynamic property names, values & if attributes exist they too are stored. The user is then prompted to select other AutoCAD entities to match. If they are blocks and have dynamic properties that are named the same it would define the stored value. Same with the attributes. Here's the kicker, they do not need to be the same block name. All I care about is the parameter names. I have attached my code & test blocks...
    Sub MatchDBlockProperties()
    Dim Prop As Variant
    Dim Prop2 As Variant
    Dim V As Variant
    Dim V2 As Variant
    Dim i As Long
    Dim blkRef As AcadBlockReference
    Dim blkRef2 As AcadBlockReference
    Dim oBkRef As IAcadBlockReference '2
    Dim oBkRef2 As IAcadBlockReference '2
    Dim MastchVS As AcadSelectionSet
    Dim Vvalue As String
    Dim V2value As String
    Dim varAttributes As Variant
    Dim varAttributes2 As Variant
    Dim Blockname As String
    Dim Blockname2 As String
    Tag
    On Error Resume Next
    ThisDrawing.SelectionSets.Item("MastchVS1").Delete
    Set MastchVS = ThisDrawing.SelectionSets.Add("MastchVS1")
    On Error GoTo exitsub
    ThisDrawing.Utility.GetEntity blkRef, pt, "Select Dynamic Block to reference: "
    If blkRef.ObjectName = "AcDbBlockReference" Then
    Set oBkRef = blkRef
    If oBkRef.IsDynamicBlock = True Then
    Blockname = oBkRef.EffectiveName
    V = oBkRef.GetDynamicBlockProperties
    If oBkRef.HasAttributes Then
    varAttributes = oBkRef.GetAttributes
    End If
    'Next
    End If
    End If
    blkRef.Update
    ThisDrawing.Utility.Prompt vbCrLf & vbCr
    ThisDrawing.Utility.Prompt vbCrLf & "Dynamic Block(s) required to match, Please" & vbCrLf '''added
    MastchVS.SelectOnScreen
    For Each blkRef2 In MastchVS
    If blkRef2.ObjectName = "AcDbBlockReference" Then
    Set oBkRef2 = blkRef2
    If oBkRef2.IsDynamicBlock = True Then
    Blockname2 = oBkRef2.EffectiveName
    'If Blockname2 = Blockname Then ******** REMOVED NAME REQUIREMENT TO ALLOW MATCHING OF JUST DYNAMIC PROPERTIES 4/30/15**********
    V2 = oBkRef2.GetDynamicBlockProperties
    For i = LBound(V) To UBound(V)
    Set oDynProp2 = V2(i)
    'If Prop2 <> "Origin" Then
    If V2(i).PropertyName = V(i).PropertyName Then
    V2(i).Value = V(i).Value
    End If
    Next i
    varAttributes2 = oBkRef2.GetAttributes
    For i = LBound(varAttributes) To UBound(varAttributes)
    varAttributes2(i).TextString = varAttributes(i).TextString
    Next
    End If
    'End If
    End If
    End If
    Next
    ThisDrawing.Regen acAllViewports
    Exit Sub
    exitsub:
    End Sub
    2004-07
    Chico, CA
    158
    Default Re: Match Dynamic Property Values IF Parameter Name =
    Here is the test file...
    2004-07
    Chico, CA
    158
    Any tid bit would be helpful!
  1. Replies: 10
    Last Post: 2013-12-17, 04:25 PM
  2. Automated Property Set Values
    By MHarkins in forum ACA General
    Last Post: 2008-01-28, 05:57 PM
  3. Match Hyperlink Property
    By bzrqmy in forum AutoLISP
    Last Post: 2006-02-23, 06:19 PM
  4. Match property or property window
    By patrick.callewier in forum Inventor Wish List
    Last Post: 2005-03-22, 09:14 AM
