Thread: ACAD MEP 2016 Stability
    2008-03
    32
    Default ACAD MEP 2016 Stability
    So I've been toying with ACAD MEP 2016 the last couple days to try and decide if I want to actually use it or if I should hold off - but I've been running into major stability issues - to be exact - the program has crashed on me 5 out of the 6 times I've opened it over the past two days. A couple of times it crashed while closing a drawing and another time it crashed while starting a new drawing. Are others experiencing similar stability issues? Or is this just me?
    100 Club kleenhippie's Avatar
    2002-08
    38.7867 N, 77.4917 W
    140
    Default Re: ACAD MEP 2016 Stability
    Well of course it's just you... Autodesk is out to mess with you and only you...
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by jparkhurst View Post
    Hmm, closing and starting and other times? So, it's not just a specific command triggering the crash.
    I saw this KB article, but, that doesn't look like it will help you.
    Looks like some others might be experiencing similar issues... No clear resolutions were posted in the thread, just advice on using updated graphics drivers.
    What OS are you using? Do you work with anyone else using the same software, and are they experiencing it, too?
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. [3dsmax 2016 - Maya 2016] Extension 1
    By METANAMORPHOSE in forum 3ds Max - General
    Last Post: 2015-08-13, 11:47 AM
  2. 2016: Migrating from Acad 14 to Acad 2016
    By wilmath706257 in forum AutoCAD General
    Last Post: 2015-08-13, 03:28 AM
  3. 2016: Publish command is slow to open in AutoCAD 2016 & AutoCAD 2016 LT
    By leinsterlady in forum AutoCAD Plotting
    Last Post: 2015-07-14, 07:42 PM
  4. 3dsmax 2016 / maya 2016
    Last Post: 2015-04-15, 09:58 AM
  5. Fix Stability Issues
    Last Post: 2014-02-12, 03:12 PM
