Thread: drawing clean up lisp
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default drawing clean up lisp
    Hi everyone, I am in need of a program that will do the following:
    Save the original file that is currently open with the original file name and put -original at the end of the filename and then save it in the same folder where the currently file is.
    Perform a Audit, then run the purge command three times. For RegApps, reset the Scale List, delete DGN linetypes, and remove all proxy objects.
    Set all entities in the drawing to ByLayer, including within blocks,and then do a WBLOCK on all visible objects from all the layers in the drawing and save them together into a new file in the same folder where the original file was saved.
    Thanks for the help.
    Earth
    9,805
    Default Re: drawing clean up lisp
    Can you do each of these steps at the command line?
    I think so, which means you could do it with a script file, just do the SAVE or SAVEAS command at the end.
    SAVE = creates a copy of the drawing, and leaves you in the original drawing.
    SAVEAS = creates a copy of the drawing and takes you into that new drawing.
    Reference
    I think the only one that may be a problem is removing the proxy objects.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,719
    For Registry Applications (regapps), I developed and have been using this since 2011/2012 - it is an event-driven app (free), so no interaction from user required - automagically purges unused regapps at drawing OPEN + SAVE* for you, so you can just 'work'.
    Cheers
    Computer Specs:
    2001-12
    Newport Beach, CA
    399
    I would like it to run in the background and be a lisp.
  1. Lisp to clean and save in DXF format
    By antistar in forum AutoLISP
    Last Post: 2012-12-20, 07:14 PM
  2. Drawing Clean-up
    By dhavalpatel_us337373 in forum AutoLISP
    Last Post: 2010-08-14, 03:56 PM
  3. LISP Blocks intersecting clean up help.
    By james.hodson in forum AutoLISP
    Last Post: 2010-01-15, 11:19 PM
  4. Clean a drawing
    By gfreddog in forum AutoLISP
    Last Post: 2008-03-06, 12:42 PM
  5. LISP for Intersection Clean Up
    By zorroxxxx in forum AutoLISP
    Last Post: 2004-08-30, 09:54 PM
Tags for this Thread
