Thread: LISP to create multileader - content not working
    2011-09
    308
    Default LISP to create multileader - content not working
    Hi gang,
    I've got this routine almost working.
    (vl-load-com)
    (defun c:GRDG (/ CLA)
    (setq CLA (getvar "CLAYER"))
    (command "layer" "m" "L-ANNO TEXT" "c" "1" "L-ANNO TEXT" "")
    (Steal "SW Mleader Styles.dwg"'(("Multileader Styles"("SW ML-TXT GRDG"))))
    (setvar "CMLEADERSTYLE" "SW ML-TXT GRDG")
    (command "_.mleader" "O" "C" "M" "X" (while (> (getvar 'CmdActive) 0) (command pause)))
    (setvar "CLAYER" CLA)
    (princ)
    The issue is that when it comes to entering the text, it is happening down at the command line and not at the end of the landing.
    Also, even though the content should be MTEXT, it exits the command as soon as I enter a SPACE in the text.
    Any guidance is appreciated
    2011-09
    308
    Default Re: LISP to create multileader - content not working
    Ok,
    I got it...
    (vl-load-com)
    (initcommandversion 2)
    (princ)
  1. 2012: MULTILEADER with custom block not working (Architecture 2013)
    By bamckenzie69 in forum ACA General
    Last Post: 2013-04-12, 08:48 PM
  2. how to find multileader using Lisp?
    By Macieto in forum AutoLISP
    Last Post: 2010-10-11, 12:51 PM
  3. Multileader lisp help (mtext problem)
    By framedNlv in forum AutoLISP
    Last Post: 2010-08-09, 11:13 PM
  4. Match Multileader Content
    By rolibolibo in forum AutoLISP
    Last Post: 2009-10-07, 06:12 PM
  5. Replies: 8
    Last Post: 2007-05-18, 06:55 PM
