Thread: Linework Coding Methods
    2015-05
    Default Linework Coding Methods
    We've just started using Civil 3D 2015. Up to now, our survey field crews have been coding linework using special codes (B, E, PC, PT, etc.) before the desc. key code itself. Everything I see in C3D shows special codes after desc. key codes.
    Is there a way to make it read the special code first?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Linework Coding Methods
    I don't have an answer. However, I would recommend you try importing from one of your previous projects in the format your crews currently code. If your Figure Prefix / Linework Code Sets are configured, and it does not import as desired, then you find out your answer. It'll take some time to do this test if everything is not setup, but like most things in Civil 3D, those things will need to be explored and adjusted to fit your style of use with the software. Unfortunately, this portion of the software may require your methods to change.
    Please let us know how it works and good luck.
    2016-01
    19
    That's one of the many items I have complained to AutoDesk about for years, but the general reply has been; "Live with it." You need to remember they have little interest in supporting the Survey market and having the command after is how the programers like it.
    2015-08
    11
    I code every day 500 -1000 points a day and it draws it 99% of the time.
    I code are better after the feature code. Easier to find and less typing.
    TC B
    TC
    TC BC
    TC POC
    Starting a on a curve or maybe it is because I never use e for END.
    Connecting 4 or 5 codes
    The real PROBLEM IS THE DATACOLLECTOR . THE DESCRIPTION FEILD IS LIMITED IN LENGHT. SO IF U HAVE 3 codes and the are like. TC POC FL POC TOW B. OR TC B GB1 B GB2 B TOW AND THEN IF U WANT TO DO THE OFSETS TOO. THE DATACOLLECTOR WILL NOT LET U TYPE IN. SO CODING IN A LIMITED FIELD IS MORE CHALLENGING. BECAUSE U COULD CODE 60 CHARACTERS IN THE FIELD., BUT THE DATA COLLECTOR IS 16 -20 characters...
    I have been doing autoline work since 1991 when I wrote my own program for acad 12 / DCA.
    Over it is a real time saver. Yes it needs work but it will save u time and notes. Depends again on DATACOLLECTOR.
  1. Coding help
    By cadd4la in forum AutoLISP
    Last Post: 2013-07-08, 10:50 PM
  2. Coding help
    Last Post: 2013-06-21, 05:20 PM
  3. 2012: Linework Coding - adding extra discription for a figure
    By sgerrior219317 in forum AutoCAD Civil 3D - Survey
    Last Post: 2012-05-16, 04:05 AM
  4. Coding help.
    Last Post: 2012-04-14, 02:58 AM
  5. Site drawing linework and pipe network linework
    By GreyHippo in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-03-23, 03:11 AM
