Thread: Beam Pockets
    2012-12
    2
    Question Beam Pockets
    How do I cut beam pockets into my foundation wall? I placed the beam in my model, extended it to the middle of the wall but it just dies into the wall. I need to cut away a portion of the wall to make a pocket. How do I easily do that?
    2005-06
    in the upper right corner
    3,507
    Default Re: Beam Pockets
    Quote Originally Posted by andys View Post
    I've never actually needed to do that, usually this would be covered with a detail, not modeled.
    There may be better ways to do that but the easiest way I can think of is to edit the profile and create the step downs for the pockets, and infill with a thin concrete wall to the outside face.
    HTH
    2010-10
    Chicago, IL
    376
    You can also add a void extrusions at the beam ends in the family and use cut tool in the project to create a pocket.
  1. Legends - how to show beam-beam & beam-col conn?
    By lcamara in forum Revit Structure - General
    Last Post: 2014-05-04, 10:45 PM
  2. Concrete Foundation Embed Pockets
    By darrell.badger in forum Revit Structure - General
    Last Post: 2012-12-07, 12:54 AM
  3. Replies: 1
    Last Post: 2010-08-30, 05:46 AM
  4. Concrete beam with sloped top + Beam family question...
    By scowsert in forum Revit Structure - General
    Last Post: 2007-12-22, 03:36 AM
