Thread: Create a custom linetype with two colors
    2012-02
    82
    Default Create a custom linetype with two colors
    Good morning,
    Is it possible to create a custom linetype which is made up of dashes with every other dash a different color? What I want is a linetype to define a gas line (I know, all have to do is add text but I want to do it using a combination of two dashes. One Yellow and the second Black.) I found a suggestion for using Mline which produces a two tone line but the Mlines can't be Offset nor can it be an PLINE.
    Cairo - no, not Illinois
    5,069
    Default Re: Create a custom linetype with two colors
    Not in AutoCAD, not using a Line or Pline.
    A custom routine could be created that faked it, but you'd end up with multiple segements (which could be GROUPed together)
    2009-11
    5,719
    Can you instead use two, overlapping lines... One continuous (Yellow), and one with your dashed linetype (Black)?
    Cheers
    Computer Specs:
  1. Create a custom Sheet Pile LineType
    By Jay Zallan in forum AutoCAD Customization
    Last Post: 2010-06-17, 03:29 PM
  2. Create a custom Linetype - silt fence
    By gcameron in forum AutoCAD Customization
    Last Post: 2007-06-21, 10:40 PM
  3. Create a custom linetype with an Arc in it
    By tyeelaw13 in forum AutoCAD Customization
    Last Post: 2006-07-14, 03:49 PM
  4. Create a custom Fence linetype
    By Damian_E in forum AutoCAD Customization
    Last Post: 2006-07-12, 08:18 AM
  5. Create a custom bold dot linetype
    By nanoaguilar2000 in forum AutoCAD Customization
    Last Post: 2004-09-28, 06:19 PM
