Summary: Flat patern orientation on drawing should NOT change while modifieng part. Now the orientation changes (view rotates) with no logic. All measures are somhow corrupted after rotation (need modifing)
Description: Flat patern orientation on drawing should NOT change while modifieng part. Now the orientation changes (view rotates) with no logic. All measures are somehow corrupted after rotation (need modifing). This is very simple to reproduce... Create sheet metal part like u-section. Make some holes to part (non symmetrically) Create flat pattern. Create drawing and place flat pattern view as 2nd view. Make some dimensions to flat pattern. Edit the part by adding round to outer corners. Return to drawing and it's (f****d up) .
Product and Feature: Inventor - Sheet Metal
Submitted By: Pasi Annila on 05/27/2015
