Results 1 to 10 of 16
Thread: Current updates for Revit 2015
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    592
    Thumbs up Current updates for Revit 2015
    Keep track of updates to Revit 2015 products.
    If you want to follow along check you are logged in, look right, click on Thread Tools and subscribe as shown below:
    As I write this the latest update is number 14. See Autodesk's Read me and Update Enhancement List for info.
    I can save you the trouble of looking it up by listing the four changes here:
    * Improves stability during Sync with Central>Reload Latest when project utilizes Revit Server
    * Corrects an issue which prevented the replacement of an existing project within Revit Server
    * Improves stability when reloading links within work shared projects.
    * Improves stability during creation of a stair by component when the stair path text type becomes invalid.
    Have you tried out the Autodesk desktop app? Is it helping you keep track of updates?
    If you need to know what your current build (version) is, take a look at How to tie the Build number with the Revit update (thanks dkoch)
    2002-09
    Madison, WI
    5,566
    Default Re: Current updates for Revit 2015
    Done.
    If anyone would care to make a thread for 2016 I can stick that one too.
    Steve can overrule me later.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2019 w/ A360 - Navisworks - 3ds 2019 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-09
    Denmark
    592
    I just had a problem updating a machine with Revit 2015. It sat stubbornly at some earlier build number and would not install R2 update 8. I uninstalled Revit 2015 and went through 2015: How to Complete a Clean Install and Uninstall of Revit products, but it still didn't work. So I installed UR2 Update 4, and then R2 Update 8 - voil√° it worked. Hope that helps someone.
    2004-06
    Memphis TN area
    7,046
    How do I know if R2 is installed? I have the full functioning Revit 2015 (all disciplines) from Building Design Suite, so does R2 even apply to me? We also have 5 other seats of Revit Architecture so how do I know if R2 is installed on those machines?
    AERC, PLLC
    Hernando, Mississippi
    2003-03
    Philadelphia, PA
    2,357
    Quote Originally Posted by patricks View Post
    You would have had to have downloaded the installation file for R2 from the Subscription Center (or, now, Autodesk Account - Product Enhancements). So far as I know, the R2 version was only released as the Revit ("One Box" - all disciplines) program and was not made available for Revit Architecture, Revit Structure or Revit MEP.
    You can check the current build you are using by selecting About Autodesk Revit 2015 from the Help pulldown in the Info Center (upper right corner of the Revit window). You can compare what shows there to the list in this Autodesk Knowledge Network article.
    David Koch
    2006-09
    Denmark
    592
    Quote Originally Posted by dkoch View Post
    It was/is also released for Revit Architecture, as shown in my original post. I assumed it's there for the other disciplines, but I could only find Revit Structure R2 update 7 but not 8. Haven't looked for MEP.
    2006-09
    Denmark
    592
    Added update 9
    2004-06
    Memphis TN area
    7,046
    My gosh, update NINE??? Was 2015 that bad that this many updates has been needed? I can barely even keep up with them all, and I only have 7 machines in the office that need the updates.
    Any why are they still putting out updates when 2016 has been out for over 4 months now?
    AERC, PLLC
    2002-09
    Madison, WI
    5,566
    Many of these updates were due to the introduction of C4R (A360).
    Also from my understanding this is going to be the "new normal" for updates. No more large updates that take forever to download and never get installed in time.
    They want to do smaller, quicker updates sim to what they were originally doing when they would still kick out hot fixes.
    Dave Peterson
    BIM Coordinator
    2004-06
    Memphis TN area
    7,046
    So now, in order to be signed into A360 in Revit, your workset user name MUST be the same as your A360 email address??? What the heck kind of BS is that?! I don't want a bunch of email addresses as our workset user names. This is insanity. Most of my users don't have Autodesk/A360 accounts anyway, and I would prefer that our workset names all have the same naming convention (not some workset names as email addresses and some of them not).
    AERC, PLLC
  1. 2016: Current updates for Revit 2016
    By Duncan Lithgow in forum Revit Architecture - General
    Last Post: 2016-09-19, 08:23 PM
  2. Replies: 8
    Last Post: 2016-04-20, 06:41 PM
  3. Windows XP - Autocad MEP 2015 and Revit 2015
    By wiegmanroger433258 in forum Operating Systems
    Last Post: 2015-01-15, 01:42 PM
  4. Where to get Revit SP updates?
    By still.james in forum Revit - In Practice
    Last Post: 2008-01-17, 01:06 PM
  5. How do you all roll out updates to Revit?
    By cparsons in forum Revit Architecture - General
    Last Post: 2007-06-18, 10:55 PM
Tags for this Thread
