Thread: 1st level objects greyed out and visible on 2nd level floor plan
    2012-11
    6
    Default 1st level objects greyed out and visible on 2nd level floor plan
    This may be an easy one but as I am currently teaching myself revit this issue is stumping me. Any help is much apprecitated.
    Why are my 1st level walls and lighting fixtures seen on my 2nd level floor plan as being greyed out. Objects on my 2nd floor plan have normal line weight and color except with the additional objects mentioned above in grey and can also be selected and moved. I have a floor and drop down ceiling seperating said floor levels so I am a bit confused.
    Thank you.
    2002-09
    Madison, WI
    5,688
    Default Re: 1st level objects greyed out and visible on 2nd level floor plan
    Do you have an underlay setup in the view to display the first floor?
    2012-11
    6
    Thank you. That was exactly the issue.
  1. Change Associated Level of Floor Plan
    By m_cahoon14336 in forum Revit Architecture - General
    Last Post: 2015-06-12, 08:58 AM
  2. Ability to change the Associated Level of a Floor Plan after it has been created
    Last Post: 2013-06-07, 11:00 PM
  3. Can a floor plan become a level?
    By david.kingham in forum Revit Architecture - General
    Last Post: 2005-07-07, 09:27 PM
  4. Varying Floor Level Plan View
    By artitech in forum Revit Architecture - General
    Last Post: 2005-07-02, 12:18 PM
  5. 2x2 ceilings are visible on floor plan level?
    Last Post: 2004-08-20, 01:22 PM
Tags for this Thread
