Summary: Make is possible to create dependent ViewTemplates
Description: It would be great if is will be possible to create certain dependency in the ViewTemplate or make it possible to link ViewTemplate to each other especially for setting of ViewRange and RVT links.
ViewTemplates are there to make work easier for you, but if you have a lot of ViewTemplates to push your settings, view range, RVT links etc. and something changes you have to change all, although it will be all the same.
Even better ir will be if ViewTemplates can be exported to xml, like the search sets in Navisworks. And can be imported back...
Product and Feature: Revit MEP - Other
Submitted By: rolph baggen on 06/16/2015
