Results 1 to 8 of 8
Thread: extrusion on column face
    2011-05
    10
    Question extrusion on column face
    Please help me figure out how to create an extrusion on a column face. I realize that extrusion may not be the proper tool to use. I am at a loss as to how to achieve this. I am trying to create a purely aesthetic piece of a column that is man like figure extruded from the round / curved face of a column.
    AUGI President Kimberly Fuhrman's Avatar
    2015-10
    York, PA
    63
    Default Re: extrusion on column face
    Create a generic model on a vertical work plane. Use void cuts to emulate the curve of the column, as well as any detail features. Personally, I would create this as a family and insert it into the project.
    It requires a very unusual mind to undertake the analysis of the obvious.
    --Alfred North Whitehead
    Kimberly Fuhrman, LEED AP BD+C, Assoc. AIA
    2011-05
    10
    This reply would be helpful for a simple extrusion but I am trying to create a stick man like figure. I can't see how this would not cut off some features of the figure creating an extrusion in this fashion.
    2002-09
    Madison, WI
    5,687
    Can you provide a sketch/image of what you're trying to accomplish?
    I'm sure we can you some great ideas.
    2011-05
    10
    Here is an image of the finished column. The extrusion of the man is what I am trying to accomplish.column extrusion.JPG
    2011-05
    10
    Any suggestions guys?
    2002-09
    Madison, WI
    5,687
    You'll have to have a specialty column and I wouldn't want to make it a structural type cause that just add a lot more complexity.
    So you have one extrusion from the base to the first notch.
    a second one at the notch, and a 3rd above that.
    That gives you the round shape.
    Next you'll need to create an extrusion or sweep (either one should work) in elevation and pass it thru the column.
    This gives you the little guy.
    Then you you'll need to create a void form to cut off the rest of the extrusion that created the little guy.
    No idea how the heck you'd make that flex with with regards to the column dia and the little guy, but the rest is rather easy.
    Edit.
    Just for fun I think I'll try to make one quick.
    2002-09
    Madison, WI
    5,687
    Here you go.
    Again not a lot of flexibility in it, but....
  1. Moving vertical bracing to the inside face of a column
    By matthewc180975 in forum Revit Structure - General
    Last Post: 2012-10-14, 11:27 PM
  2. Beam to column face
    By Grumple in forum Revit Architecture - General
    Last Post: 2009-10-16, 02:45 PM
  3. Disconnecting face-based extrusion from a work plane
    By RobertB in forum Revit MEP - Families
    Last Post: 2009-09-29, 05:10 PM
  4. Help on Column Extrusion
    By ssengle in forum Revit - Student Support
    Last Post: 2009-05-26, 04:12 PM
  5. extrusion and face hosted nested family
    By mwiggins121466 in forum Revit MEP - Families
    Last Post: 2008-06-20, 05:47 PM
