Thread: view template applied to each placed view
    2010-04
    140
    Default view template applied to each placed view
    wondering if there's a way that when I place an elevation view or cut a section view that I can preset a view template to said view? as apposed to what I do now having to place each view and applying said view template to each view. just want to expedite the process.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: view template applied to each placed view
    In the Project Browser, you can <ctrl> select multiple views and then click the View Template button on the Properties pallet to assign them all the same View Template. You can also do this by <ctrl> selecting the placed views on a given sheet (or even multiple sheets), but I generally apply view templates long before I place views on sheets.
    2002-09
    Madison, WI
    5,688
    We've created different view type for each type of section and elevation (ie interior elevation, Building elevation, Building Section, Detail Section...Curtain wall detail section...) and then by default we have a template applied to each of them. You can do this when you modify the view type you can select which view template you'd like to apply.
    We've done this more so we can organize our project browser better.
  1. 2014: View set with a template changes without a template change
    By david_peterson in forum Revit Architecture - General
    Last Post: 2014-12-11, 06:25 PM
  2. 2012: View Template
    By rdooley944157 in forum Revit MEP - General
    Last Post: 2012-09-13, 03:51 PM
  3. View Template & View List
    By Cathy Hadley in forum Revit Architecture - General
    Last Post: 2004-12-31, 05:44 PM
  4. Attach View Template to View
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2004-09-21, 05:43 PM
  5. Wall sweeps applied in plan view
    By razorx1858 in forum Revit Architecture - General
    Last Post: 2004-03-04, 04:08 AM
